I have seen similar posts that suggest eliminating internal property script bindings into components, however, deleting them did not seem to lower more than 70-80%. Any recommendations to address this issue would be highly appreciated.
Have you considered the possibility that you might just need more cores in your server?
Aside from that, you will want to monitor the thread performance by subsystem, both when CPU is low and when pegged, and also collect thread dumps in the various states.
If you don’t feel comfortable with this, you should call support so they can look over your shoulder.
We have added 2 more cores this morning but there isn’t much improvement on the CPU over usage. Is there an email I could proceed with a support case please? Thanks for your help
