CPU temperature in windows
I want to read the CPU temperature of my PC that it have windows 10 installed inside.
How can do this by a python script?
Is possible?
I have find this library “psutil” but it do not work.
You could perhaps use SNMP?
Someone made a simple module for free that you might be able to use:
You could also use:
Kymera Systems Inc | IIoT Solutions - Kymera SNMP Driver , but that one is not free.
You might have to do a bit of research to find the right OID etc. This post could be a good start:
Another technique could be to run a batch file with system.util.execute(). This post might be a good start:
You can use this power shell function, but it has to be run with admin privileges, which i think ignition do have
function Get-Temperature {
    $t = Get-WmiObject MSAcpi_ThermalZoneTemperature -Namespace "root/wmi"
    $returntemp = @()
    foreach ($temp in $t.CurrentTemperature)
    $currentTempKelvin = $temp / 10
    $currentTempCelsius = $currentTempKelvin - 273.15
    $currentTempFahrenheit = (9/5) * $currentTempCelsius + 32
    $returntemp += $currentTempCelsius.ToString() + " C : " + $currentTempFahrenheit.ToString() + " F : " + $currentTempKelvin + "K"
    return $returntemp
Get-Temperature
