Hello,
I am playing around with Ignition and slowly building a system to run side by side with my existing Ifix system.
I say slowly because I keep getting sidetracked by other jobs that come up. I am starting to build up my tag database and am currently monitoring 18 tags at varying scan times with no scan time less than 50000 ms.
I am not running any clients off of this gateway but notice that with ignition running my base cpu usage holds steady at 50% with spikes up to around 56% when a scan takes place.
This is an intel core 2 duo processor with 2GB of ram with windows XP os. I am curious as to why the gateway (java.exe process) is using this amount of cpu time on a constant basis.
The gateway version is 7.1.6.
Thank you for your help.
