When I access my Ignition gateway, the CPU usage shows -100%. I’ve tried rebooting the gateway and it didn’t fix the problem.
I’m running Ignition version 8.1.14
Which page is it exactly? Can you add a screenshot?
Anything weird to note like running in a VM? What OS and CPU?
I noticed the same problem with 2 recently installed gateways. One of them is full Ignition running on desktop (i7-10700K, Win 10 Pro, clean, first-time install), the other one is Edge version running on my laptop (i7-7700HQ, Win 10 Home, multiple version were installed before), both running v8.1.15 in Trial Mode. The value of system tag “CPU Usage” is also -1.
We get our CPU load from the JVM… Tracing through some of the code on the JVM metrics side of things, I think we’re seeing this bug (where there is a code path that returns -1, which we then multiply by 100 to get the CPU load in normal situations):
https://bugs.openjdk.java.net/browse/JDK-8265104
I haven’t dug deeper yet as to discover the specifics on how this is manifesting though…
Cross-posting this here too:
This one worked for me.
