I have 4 Turbine , I would like create a table per Turbine
Repport Table
I created a param Turbine but I do'nt kwow how set it dynamique.
The problem is My repport still Turbine 1
What I want is a table per Turbine
Sommeone can tell me what is wrong ?
Sounds like what you want is child tables.
Thank you for your answer.
I created child table but, all table have Turbie number = 1
Maybe because I set param = 1 ?
To figure out if it's you're table layout or if it's the data, look at the right sidebar in the Preview tab -- that's the data which is going in to the report.
You'll notice that your parameter for Turbine is a string -- this isn't something that can hold multiple values. You will likely need the turbine numbers to come from a query, with subqueries for the data for each turbine.
@KathyApplebaum Thank you for you suggestions
If I do a query,with subqueries for the data for each turbine like you recommeded me, how I will defined the paremeter below on >>>>Historial Tags because I'am using **Tag History ** data
Check out the docs on nested queries or the IU video on nested queries. Both have examples of how to do exactly this.
