Hello,
I want to know if it is possible to create an alarm without using a tag
For exemple,
I have to values
b = 3 and b =10
if a>b:
Active alarm and Write stats of alarm on “Alarm Status table Display”
Hello,
For exemple,
I have to values
b = 3 and b =10
if a>b:
The top line here: Alarming, says that “Alarms are always configured on a Tag”.
The bigger question is why do you want to not use a tag?
I don’t want use tag because I create a tag memory, I configure an alarm but I can’t write a value on a Setpoint with a script. On my view, I have a Textfield and I want put this Textfield on a Setpoint of my alarm.
But if sommene know how I can’t take a value of a Textfield and bindit it with my SetPoint of my alam, it will also solve me.
You can configure alarms via script with this function:
https://docs.inductiveautomation.com/display/DOC81/system.tag.configure
An other big question might be: What is the alarm for ?
I would like to monitor the operation of a motor using a graph.
In fact on the graph, I calculated the maximum values over a time interval.
And I would like to send the value calculated on the Setpoint of my alarm
Your baseTagPath is wrong… it should be:
baseTagPath = "[Formation]m1"
I still fail to see the point of the alarm here. What does it do ?
I need use alarm to monitor my engine operation.
I will compare my tag value and Setpoint value of alarme.
if Setpoint is Above tag value I will active an alarm.
[formation]m1 needs to be a folder, and it appears to be a memory tag in your tag browser.
Let’s take another approach:
Create a memory tag named calculatedSetpoint.
Then in your m1 tag, in alarms config, bind Setpoint to that calculatedSetpoint tag…
calculatedSetpoint tag and it will trigger the alarm if the m1 value is above the setpoint…
That’s probably a better way to do it, indeed.
thank it work good.
