How do I create new columns in Ignition from a SQL Column. SQL column contains different names, then I want to use those differente names to create headers and count how many times repeat those names. Column in SQL is Area
Can you show an example of what you want as your result, using that screenshot?
It sounds like you could just use a query to do this:
SELECT Description, Count(Description) as Count
FROM YOUR_TABLE_NAME
GROUP BY Description
ORDER BY Description
In that case, you’ll need to look into using a PIVOT:
Thanks!
