Is it possible to create a temporary table or dataset in Ignition and Log the Tags/Query output to the created dataset or table
Perspective or Vision ?
If you are looking for dataset tag then here is the reference
Thank you for sharing the thread. In addition to this, I also need suggestion on how to Insert values to the Created dataset from different tags dynamically
Please describe the real problem you are trying to solve. There may be a better way.
How to write a value to the dataset datatype tag.
I need to add/write the value to the dataset datatype tag from other tags.
eg., If we configured a dataset with 2 rows and 2 columns (X and Y). how to update the values to X and Y column dynamically
Refer Altering a Dataset section
