Create list from a bigger list
Is there a simple way to make a new partial list from an existing bigger list, but in a different order?
I have
myList = [ "blue", "red", "green", "orange"]
if If try
myNewList = myList[0:2]
print myNewLIst
blue, red
how do i get blue and green
trying not to do
myNewList = [myList[0]]
myNewList.append([myList[2])
this is a simplified example of much bigger lists.
This would return blue and green from your example:
myList = ["blue", "red", "green", "orange"]
# Extract every 2nd item from first list.
myNewList = myList[0::2]
print myNewList
But I'm guessing you're not looking for every second item.
What kind of criteria/pattern would you use to select items from the old list for the new list?
If you have another list containing the indices you want, you can use a list comprehension:
mySubscripts = [0, 2]
myNewList = [myList[x] for x in mySubscripts]
You should be aware that you were mis-using both slicing and the .append() method in your OP, yielding a list within a list in both cases. Spend some time in the python docs for sequence types for the details.
Correct. The source list contains 14 items, but I want to pull out five of them in the order 2,9,3,0,1 so my SQL query will return items in the order I want to display in a table component.
my other option was
vals = myList[2]
vals.append(myList[9])
vals.append(myList[3])
vals.append(myList[0])  or optionally vals.append(myList[0:2])
vals.append(myList[1])
I think that is correct now
I was hoping there was a simple single line way to do it
As @pturmel pointed out, my OP was incorrect. I wrote that out as I was trying to leave the office.
I guess I should also figure out how to post code snippets properly as you all have done.
Nope. Missing brackets and errors with .append() still present. Starting here:
vals = myList[2]
vals is not a list. So .append() won't work the way you think. (With the above, it is a string, so .append() is expected to add a character to it.)
And the latter .append() below, if vals was actually a list instead of a string:
is adding a slice of myList (which is a two-element list) as a single element of vals, nesting it. It would yield something like [a, [b, c]].
Please, read up on how brackets work in python in the linked documentation.
Place a line with just three backquote characters above your code, and again below your code. Like so:
# Some code
You can edit your prior posts to include these and they'll magically become readable.
With that short list, you can one-line it like this (combining 2nd & 3rd lines of @pturmel's example):
vals = [myList[x] for x in [2, 9, 3, 0, 1]]
In your latter example, your first line would need to look like this to make it a list (rather than a string):
vals = [myList[2]]
To get the expected result from this line:
You'd need to replace append with extend.
I think I get it
This works
		selCols = project.globalVars.PART_STANDARDS_COLS[0:]							# get all columns
		print selCols
		whereCols = [project.globalVars.PART_STANDARDS_COLS[0]]							# Where column 0 and 2, . partNo and ViewID
		whereCols.append(project.globalVars.PART_STANDARDS_COLS[2])						# LAME
		print whereCols
		table = "PARTSTANDARDS"
		retValA,pyDataSet1 = project.db.dml.selectData(selCols,whereCols,whereVals,table,database)		# don't need optional order or sort
and so does this, but for different reasons
		selCols = project.globalVars.PART_COORDS_COLS[0:]				# get all columns, create new list
		print selCols													# print result
		whereCols = project.globalVars.PART_COORDS_COLS[0:2]			# Where column 0 and 1, . partNo and ViewID, create new list
		print whereCols													# print result
		table = "PARTCOORDS"											# table
		retValB,pyDataSet2 = project.db.dml.selectData(selCols,whereCols,whereVals,table,database)		# don't need optional order or sort
it depends if the “:” is present in the list reference whether the result is a list or a string, among other things.
The source lists are pre-defined in script modules
