In our company we have an Ignition Edge connected to an Igntion Central via GetwayNetwork.
Ignition Edge tags are historicized to an Ignition Central history provider.
For a power chart, I need to programmatically create the pens datasource from the tag path.
For example:
Tag path: [remtagElBonillo]UP1/Inverters/Inv1/RT/Current/AC
Expected Pen Datasource:
"histprov:elbonillo:/drv:ignition-elbonillo:tagedge:/tag:up1/inverters/inv1/rt/current/ac"
If I try to get the necessary values with readBlocking, I get the parameters that correspond to the remote tag, for example History Provider = "histEdge", but I need History Provider = "elbonillo".
So the solution would be to access the parameters of the Real Time Provider (Edge Remote) programmatically. Is it possible to read these parameters somehow?:
Best Regards.
