Hello,
I’m having issues when Ignition tries to create a new table, whether that be via the Tag History Browser and/or the Transaction Group. When I copy the Create Table Query and paste into SQL Management Studio I receive an error related to the syntax. SQL Doesn’t like the (`) I believe the syntax should be (’).
Full Error:
java.lang.Exception: Error running query: CREATE TABLE group_table (`group_table_ndx` int NOT NULL AUTO_INCREMENT,`RandomInteger2` int,`RandomDouble2` double,`RandomInteger1` int,`RandomShort2` int,`RandomLong1` bigint,`RandomLong2` bigint,`RandomBoolean1` int,`RandomBoolean2` int,`RandomDouble1` double,`RandomShort1` int,`t_stamp` datetime,`quality_code` int,PRIMARY KEY (`group_table_ndx`))
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:140)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.createTable(DBTableSchema.java:109)
at com.inductiveautomation.factorysql.groups.AbstractTableItemGroup.checkTableStructure(AbstractTableItemGroup.java:186)
at com.inductiveautomation.factorysql.groups.AbstractTableItemGroup.prestartCheck(AbstractTableItemGroup.java:122)
at com.inductiveautomation.factorysql.groups.AbstractGroup.startExecution(AbstractGroup.java:309)
at com.inductiveautomation.factorysql.ProjectRunner.loadGroupResource(ProjectRunner.java:281)
at com.inductiveautomation.factorysql.ProjectRunner.lambda$onResourcesModified$2(ProjectRunner.java:173)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.inductiveautomation.factorysql.ProjectRunner.onResourcesModified(ProjectRunner.java:173)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycle$LifecycleResourceListener.resourcesModified(ProjectLifecycle.java:176)
at com.inductiveautomation.ignition.common.project.AbstractProject.notifyResourceListeners(AbstractProject.java:349)
at com.inductiveautomation.ignition.common.project.AbstractProject.updateEffectiveState(AbstractProject.java:151)
at com.inductiveautomation.ignition.common.project.RuntimeProject.applyChange(RuntimeProject.java:271)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.lambda$updateOrStartAffectedProjects$5(ProjectLifecycleFactory.java:181)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.updateOrStartAffectedProjects(ProjectLifecycleFactory.java:161)
at com.inductiveautomation.ignition.gateway.project.ProjectLifecycleFactory$1.projectUpdated(ProjectLifecycleFactory.java:139)
at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.fireProjectUpdated(BaseProjectManager.java:811)
at java.base/java.lang.Iterable.forEach(Unknown Source)
at com.inductiveautomation.ignition.gateway.project.BaseProjectManager.push(BaseProjectManager.java:516)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.Projects.push(Projects.java:218)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:225)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:409)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:190)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:335)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:61)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:126)
at org.eclipse.jetty.server.Server.handle(Server.java:530)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:347)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:256)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:708)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:626)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near '`'.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:217)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1655)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:885)
at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:778)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7505)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2445)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:191)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:166)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeUpdate(SQLServerStatement.java:703)
at org.apache.commons.dbcp2.DelegatingStatement.executeUpdate(DelegatingStatement.java:322)
at com.inductiveautomation.ignition.gateway.datasource.DelegatingStatement.executeUpdate(DelegatingStatement.java:80)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRStatement.executeUpdate(SRConnectionWrapper.java:857)
at com.inductiveautomation.ignition.gateway.db.schema.DBTableSchema.executeCommandSet(DBTableSchema.java:138)
