Create xml file when alarm happens
I apologize if there is an already documented way to do what I am asking, but I work in a different department than the one that maintains the Ignition SCADA software and am not very familiar with the software. I have been given a project that has a requirement of sending an SMS message when a particular alarm condition happens in the SCADA software. The tricky part is that the SCADA software is on a network with no connection to the internet and I am not allowed to connect any celluar modems to send out text messages. Which means I can not use the already created SMS modules that the system has.
So what I would like to know is can I have the Ignition software create an xml file when my alarm condition happens? It would be great if I could include a timestamp and a data point.
I have a way that I can take the xml file and ultimately transmit it to an internet connected machine that could then send the text message. Thank you in advance.
-Kyle
I think the most appropriate (and maybe the only?) way to do this is to write a custom module using the Ignition SDK. Unfortunately that requires quite a bit of software development (and preferably, experience with Java) chops, so unless you or someone at your disposal has those skills it might not be an option…
I’ll ask around and see if anyone has a better/alternate suggestion… if someone else on the forum has any ideas feel free to chime in :scratch:
Create a module in python. Simple example - http://stackoverflow.com/questions/3605680/creating-a-simple-xml-file-using-python
Sure, that’ll get him an XML file, but there’s no easy way I can see (from scripting) to hook into the AlarmManager and get notified whenever an AlarmEvent occurs in the first place.
You could run a script on a timer to check for new alarms -
numberOfAlarms = len(system.alarm.queryStatus(path=['*/*'])
Anytime numberOfAlarms increases, you have a new alarm, I would then probably query the Alarm Journal to determine what the new alarm was.
I think what I may do is write my own simple smtp server and use the Alert email notification functionality to send out an email when the alert happens. Then when my program receives an email have it parse out the text I want into an xml file.
So Ignition is sending a simple smtp email correct?
[quote=“sfp_it”]I think what I may do is write my own simple smtp server and use the Alert email notification functionality to send out an email when the alert happens. Then when my program receives an email have it parse out the text I want into an xml file.
So Ignition is sending a simple smtp email correct?[/quote]
Sure, with the email notification profile.
