Creating a Basic Bar Chart
Good morning Team,
I am at a loss for how to create a basic bar chart in perspective. Here is the data from the named query. I have tried to look for information to find a solution but no luck.
SELECT
Clemens.Pallet_Track.Reason_Code,
COUNT(*) as Reason
FROM
WHERE
Clemens.Pallet_Track.Timestamp > case when NOW() > DATE_ADD(CURRENT_DATE,INTERVAL 4 HOUR) then DATE_ADD(CURRENT_DATE,INTERVAL 4 HOUR) else DATE_ADD(DATE_ADD(CURDATE(), INTERVAL -1 DAY),INTERVAL 4 HOUR) end
AND Clemens.Pallet_Track.Unit_Name = ‘PT10340’
GROUP BY
Clemens.Pallet_Track.Reason_Code ;
  1. Create a binding on props.dataSources.example to your named query. You should then see a line chart.
  1. Set props.series.0.render: column and it should convert the lines to bars.
I can change it to bar, that is not an issue. The issue is when I add a binding to my to the data.
Your original question wasn’t clear about what the problem was.
Your dataSources are not set up properly.
It’s expecting an object (2) below the dataSources object (1) with the data array (3) in it.
XY data source
You must then point each series to the correct dataSource.
props.series.0.data.source: example in this example.
Tip: use the </> code formatting button when posting code. It preserves indentation and gives free syntax highlighting!
Thanks so much for the help. I will try and see if i can get it to work properly. I am not very skilled in all this :thinking:
I am not sure where exactly to bind my data. I have Reason_Code on the xaxis and Reason on the yaxis.
Here is a pic of what I have in Ignition Vision, but I am not sure how to set up in Perspective.
Here is the dataset from perspective, so I believe it is running correctly. I am having trouble binding it all properly.
In the Perspective Project Browser find your XY Chart, right-click on it and select Copy.
Paste it in here using the </> code formatting button. If you want to make your post nice and compact then select the whole code section, hit the gear icon and select Hide Details. You’ll then get a collapsible section as shown below.
XY Chart JSON
    "code": "goes here",
    "collapsing": "is good"
Thanks so much for the help Transistor!! I think i posted this as you suggested.
[details="Summary"]
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "xAxes": [
          "name": "time",
          "label": {
            "enabled": true,
            "text": "Time",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy-MM-dd kk:mm:ss",
            "format": "M/d"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#,###.##"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "name": "process temp",
          "label": {
            "enabled": true,
            "text": "Process Temp",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "M/d/yyyy HH:mm:ss"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": null,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
          "name": "output temp",
          "label": {
            "enabled": true,
            "text": "Output Temp",
            "color": ""
          "visible": true,
          "inversed": false,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "M/d/yyyy"
          "value": {
            "range": {
              "min": "",
              "max": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": true,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "4,4",
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "label": {
          "visible": true,
          "hiddenInLegend": false,
          "defaultState": {
            "visible": true
          "data": {
            "source": "example",
            "x": "t_stamp",
            "y": "process_temp"
          "xAxis": "time",
          "yAxis": "process temp",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name}: [bold]{valueY}[/]",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "label": {
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "t_stamp",
            "y": "output_temp"
          "xAxis": "time",
          "yAxis": "output temp",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "fill": {
                "opacity": 0,
                "color": ""
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "fill": {
                "opacity": 0,
                "color": ""
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
    "meta": {
      "name": "XYChart"
    "position": {
      "x": 237,
      "y": 188,
      "height": 375,
      "width": 435
    "custom": {},
    "propConfig": {
      "props.dataSources": {
        "binding": {
          "type": "query",
          "config": {
            "queryPath": "CFG Queries/Pallet to Hospital Monitor"
[/details]
Hey, I found your post because I’ve been struggling with the same thing for a while now i found you must name these properties ( pictures below, i tried to colour code which ones need to be the same ) exactly the same as they are named from your data source. This includes case sensitivity.
this component is extremely temperamental so approach with great patience. Hope this helped you
Also, i found you must bound your query to example, not datasource otherwise it is not happy.
Thansk Dean, I will try this. I did try this but probably had it wrong.
Id also recommend starting with a fresh chart so all the settings are ok let me know if it still doesnt work
This is not true, you just have to insure that the values are returned in the format that is expected. Easily achieved by the use of a script transform.
For instance if you want to have multiple dataSources how would you achieve this if you were binding to "example"?
Instead Transform the returned query data:
return {'yourDataSourceName':value}
Then just make sure that each props.series[x].data.source is set to yourDataSourceName.
I didn’t know you had replied to my answer. You need to use the syntax @username if you want to ping someone.
The JSON you posted has the binding to the data but doesn’t have the data itself. I think you need to disable the binding (temporarily) and then copy and paste again into a new post. Check that the data is in the JSON before posting.
I can see from what you have posted, however, that you don’t seem to have followed the advice I give in my first post. You need the structure indicated by items (1), (2) and (3). You seem to have created a binding on (1). That’s not correct. You need to create an object (2) and bind to that. Then your series need to point their series.0.data.source to that object as shown in my first post.
You should have gotten a notification anyways, just from participating in the topic. Pinging someone is what you do to get their attention when not participating.
At the bottom of the topic you should see a "Watching" indicator when you've participated. (You can change that to stop future notices.)
