You're going to have to stop doing this. Once you have multiple real clients using your system, your own client and designer activities on the server will negatively impact the performance of the gateway service. It can also give you a false idea of what is possible for clients if the environment you are designing in has local access to the gateway's files.
This is also why I tell my clients to not install directly on their own workstations. Always use a VM or container technology if you don't have a dedicated gateway machine.
