Creating a client tag thru script
Ignition 8.0.12
We try to create a vision client tag in a function by using the function ‘system.tag.configure’, but without any desired result.
Can someone provide us with a small sample script in which this works successfully? We can create standard memory tags with this function.
For example, should the parameter ‘tagGroup’ have a value? This is not necessary with standard memory tags.
Client tags are created from project resources, not as stand-alone entities. They are not part of the infrastructure for gateway tags. I don’t think you can make this work, except possibly with undocumented, likely-to-be-broken-soon SDK interfaces.
It's not possible to load in or create client tags dynamically in 8 (at least, at present) due to the changes in the tag system. Some more info in this thread:
hello Paul,
is there any update about that functionality?
thanks in advance.
No. Frankly, it's a low priority task because few people ask about it. An ideas post (ideas.inductiveautomation.com) would help us gauge community interest in a more impartial way.
A reason it would be nice to have the ability to create client tags at runtime is for inherited resources. The parent resource might use client tags and the child might not have them. Having the inherited resource run a script to create the necessary tags would make sure they are always there, no matter how many different children there are.
As Phil said way back here, Creating client tags in runtime - #8 by pturmel , client tags are very powerful for [the reasons he gives].
I headed over to http://ideas.inductiveautomation.com/ and the thread I found there on this topic was closed in 2014. I cast my vote and made my case regardless.
