Creating a pump characteristic curve
Hello there,
What is the best approach to creating a pump characteristic curve in Ignition?
Can it be done using one of the included charts?
Thanks in advance for your help.
What’s the purpose of this? Do you also want to display the operating point dynamically in this chart? You may have to define a custom template for such a component.You need an XY plot, don't know if supported in designer or perspective .
The classic chart in XY Plot mode will work. You will want to change the X-Axis to be a number axis. It is a DateTime axis by default.
Thanks for the responses. The original chart example I was provided has axes on the left, bottom and right, as well as various other metrics superimposed on the curve but after getting some clarification from the customer it seems that a simple XY plot will suffice.
