Good afternoon,
I am working on a new report using the reporting module, and what i'm trying to accomplish is instead of having it show a set time range, I want to to show the range when a circuit is active. Is that achievable?
Thanks in advanced.
Good afternoon,
Thanks in advanced.
That would be Duration On. I had a hard time finding documentation on it, this link explains it a bit, regardless if you use this function or not.
https://docs.inductiveautomation.com/display/DOC81/system.tag.queryTagHistory
Thank you, when I try and enter this into the Data section of the Report Module it doesn't recognize this expression.
Use tag history data source,
