What is a robust way to generate a UID to use as a barcode identifier in a report. I did have the barcode representing the information directly, but now there is too much info to encode as a barcode. Now I must associate the data with a UID in my database to get the info I need when I scan. Looking for suggestions on the best way to generate the UID.
EDIT: The UID will be entered into the database along with the associative data in a button script.
https://docs.oracle.com/javase/7/docs/api/java/util/UUID.html
from java.util import UUID
uid = UUID.randomUUID().toString()
Cool, it generated too long of uuid though for my barcode usage so I used this instead
uid = UUID.randomUUID().getMostSignificantBits()
print uid
my results went from something like this
11cda468-aa5b-4c5f-baf0-d16a39027c2e
to this
349008164283105895
Do I have to worry about any collisions with this method?
Not significantly - the randomUUID() function is generating a “true random” (type-4) UUID, so either slice of the 128-bits should be equivalently random. Collisions within a 64-bit space should be incredibly unlikely.
