Hi
I’m trying to pull from tia portal a bit from an INT.
The Int tag lies an a Database (100) with an offset of 3, all 16 bits are occupied and I’d like to get the bit value’s
Would I then configure the tag editor as boolean if I’m trying to get to the bit value?
And would it have the structure as:
[Siemens_Device]DB100,X3.1
or would I have to use " IX "?
I’ve been told that reaching for the bits of an int from tia portal to siemends was a bit difficult but because of the way the int’s are structures in siemens, but im not so sure how to go about it.
Thank you all
