table { border: 1px solid #c4c7c5; border-radius: 4px; font-size: 16px; } th { padding: 18px 16px; text-align: left; } td { padding: 16px; border-top: 1px solid #c4c7c5; } .katex-mathml{ display: block; text-align: center; } .katex-html { display: none; }
Hello Guys
I’m currently working on a project where I need to dynamically create alarms. I’ve set up a UDT instance in Ignition Edge and am transmitting data to standard Ignition. In my project, I have 14 folders, each containing identical tags that require alarm configuration.
To streamline this process, I’m looking for a way to automate the alarm configuration instead of manually setting it up for each tag. I attempted to use the system.tag.configure function, but I encountered a BadAccessDenied error, indicating as Insufficient Tag Provider Edit Permissions. This issue persists even when I use admin credentials.
Does anyone have suggestions on how to resolve this or alternative methods for dynamically creating alarms? Any help would be greatly appreciated. Thanks in advance!
baseTagPath = "[MQTT Engine]Edge Nodes/MxD/Chicago/Assembly Area01/Line01/Stn1/Health Check/Fault/Current Fault"
alarms = [
"name":"My scripting alarm",
"mode":"AboveValue",
"setpointA":10
tags = [
"alarms":alarms,
"name":"myTag"
]collisionPolicy = "m"
system.tag.configure(baseTagPath, tags, collisionPolicy)
I have tried using this script as i mentioned i got error stating "[Bad_AccessDenied("Insufficient Tag Provider Edit Permissions"
