Hello everyone, Depending of some data, If I got an error I will save that to send that error as an alarm in the table status alarm or in a normal table, did sombody know if this is possible ? Thanks
I am not sure if with that error I can create manually an alarm
Could you be more specific about what sort of error would trigger this?
An error from a script as receiving a code that means an error, then send the error
Check out this post Add Alarms records in alarms History
It can be a little tricky, but you can manually add to the database. The key is making sure you format it correctly on creation.
