Creating an Ignition Container with a hardened OCI base image
I’m implementing Ignition in a highly cyber secure environment and I’d like to use containers, but I will need to rebuild the Ignition container using an OCI hardened image as the base layer (instead of Ubuntu 24.04 that Inductive uses).
It would be nice if Ignition shared the image build script/layers for generating the “official” images so I could reconstruct a container without all the CVE’s and have it pass a cyber audit. Does Inductive publish (or can they) the Ignition container source scripts?
In lieu of that, I’ve found some older Git projects that generate Ignition containers that seem to be more complicated than the existing one and I’m concerned it doesn’t have the support for the same container features found in the Ignition documentation. Is there a reliable source for an Ignition container that can be changed to a hardened OCI image?
Ideally I’d like to change the base OS to Redhat 9.5 (or up to 10 later when it is approved), any pitfalls to changing from Ubuntu 24.04 to Redhat (aside from the STIG’d environment that makes everything a nightmare)?
P.S. Yes I’ve examined the layers, but there are a few scripts and looks like a file that are transferred that aren’t in the layer definition explicitly…
Most of the "special sauce" of the container images is (deliberately) baked into the software, not the container image (i.e. recognition of certain environment variables on startup).
The most complicated things in the official image are probably the healthcheck/entrypoint (which are just shell scripts you could copy out of them easily) and the user ID mangling stuff, which I won't pretend to know anything about.
Other than that, the process of creating a custom container image is more or less the same as following the readme instructions in the so-called zip "installer" for your target architecture:
