I have an application that needs to interface with a COM API library. I’ve found a product that will create a Java interface for a given COM object (EZ JCom). Assuming it works, can I use it by building the generated Java into a custom module? Unfortunately the system I need to interface with only provides a limited WSDL interface.
Sounds possible in theory
Your module will be tied to Windows, obviously, but other than that you should be fine.
This is something that would be tied together on the gateway. There’s wouldn’t be any visual component other than what’s already available in Ignition. In this instance, the gateway is already running on a Windows server.
That’s good, it should be possible then.
