I’m working on a driver-type module and would like to create a scripting function similar to system.device.addDevice. I have several different driver types, so I’m using the ExtensionPoint system.
Here’s what I’ve got so far - it seems to be working, but it’s letting me add multiple connections with the same name, which violates the unique constraint on the BaseConnectionRecord.Name field.
public void addConnection(String connectionType, String connectionName, PyDictionary connectionProps) {
ExtensionPointManager epm = ConnectionExtensionPointManager.get();
ExtensionPointType type = epm.getExtensionPoint(connectionType);
if (type != null) {
PersistentRecord baseRecord = context.getPersistenceInterface().createNew(BaseConnectionRecord.META);
baseRecord.setString(BaseConnectionRecord.Name, connectionName);
baseRecord.setString(BaseConnectionRecord.Type, connectionType);
baseRecord.getMeta().getFieldMetas().forEach(fieldMeta -> {
String fieldName = fieldMeta.getFieldName();
if (connectionProps.containsKey(fieldName)) {
baseRecord.setObject(fieldMeta, connectionProps.get(fieldName));
PersistentRecord record = context.getPersistenceInterface().createNew(type.getSettingsRecordType());
record.setReference(type.getSettingsRecordForeignKey(), baseRecord);
record.getMeta().getFieldMetas().forEach(fieldMeta -> {
record.setObject(fieldMeta, connectionProps.get(fieldName));
context.getPersistenceInterface().save(baseRecord);
context.getPersistenceInterface().save(record);
And in BaseConnectionRecord.java
public static final IdentityField Id = new IdentityField(META);
public static final StringField Name = new StringField(META, "Name", SFieldFlags.SMANDATORY, SFieldFlags.SDESCRIPTIVE);
public static final StringField Type = new StringField(META, "Type", SFieldFlags.SMANDATORY, SFieldFlags.SDESCRIPTIVE);
public static final StringField Description = new StringField(META, "Description", SFieldFlags.SDESCRIPTIVE);
public static final BooleanField Enabled = new BooleanField(META, "Enabled", SFieldFlags.SDESCRIPTIVE).setDefault(true);
static {
Name.setUnique(true);
Type.getFormMeta().setVisible(false);
- Is my approach of creating/linking to the base record correct?
- What do I need to do to get this to respect the unique
BaseConnectionRecord.Nameconstraint?
