Creating numeric outputs with units and "number of digits" property
I am a new ignition user, It seems that the led the LED element is the only output field i have for numeric values ?
How to create a numeric output value control by my own,
I would like to have the options to customize:
  • Border Thicjness and color
  • Fill color
  • Numeric formating / number of digits, devimal points,
  • Font style and size
I have not found another numeric output field besides the LED field
So how to create a numeric output from scratch Thanks in advance.
Th
Most people just use the label component, or the numeric label in vision. Are you in vision or perspective?
I am in Perspective
Yes, use the Perspective label component. The LED display is difficult to read and is a throwback to the 1970s and "Back to the Future". With labels you can create highly legible displays with borders and backgrounds, etc.
Create a expression binding on the label and use numberFormat | Ignition User Manual function to format it.
  • Create style classes under Perspective | Styles to define your display styles.
  • In those use colors from Perspective Built-In Themes | Ignition User Manual where possible.
  • Select the style to be applied to your label from the Perspective Property Editor | PROPS | style | classes dropdown.
