Creating own Perspective symbols
how can I create symbols like these:
I mean, I want my symbols to be programmable, so I can bind tag values, etc.
What kind of 3rd party software should I use to do it?
Inkscape is free and relatively easy to use.
https://forum.inductiveautomation.com/search?q=Inkscape%20order%3Alatest
You can search "SVG" in the exchange for inspiration:
Here is a short example that uses only Ignition to do this:
Here is a more advanced example.
Don't get me wrong, Inkscape is great for authoring your own SVG's, but without a little knowledge you can produce bloated SVG's that don't help with an already performance fragile environment. Make sure if you go that route, that you know how to export Optimized SVG's for use in Ignition.
