Hi !
I’m able to build Tags from a gateway module, but I must have missed something I do understand how to give them some properties.
In my GatewayHook class I have
a SimpleTagProvider tagProvider member.
In my GatewayHook::setup method
I do :
tagProvider = new SimpleTagProvider("TheProvider");
try{
tagProvider.startup(context);
catch(Exception e)
And I have the getter method for the tag provider.
In my drivers
I have
private SimpleTagProvider tagProvider;
private ExtendedTagType tagType;
I do :
In the connect method :
GatewayHook ecoSpecHook = (GatewayHook)(getDriverContext().getGatewayContext().getModuleManager().getModule("com.example.MyModule").getHook());
if (null!=ecoSpecHook)
tagProvider = ecoSpecHook.getTagProvider();
tagType = TagType.Custom;
Set<TagProp> tagProperties = TagProp.setOf(TagProp.AccessRights,TagProp.HistoryEnabled,TagProp.HistoryTimestampSource);
if (null!=tagProvider)
tagProvider.configureTagType(tagType, TagEditingFlags.STANDARD_VALUE,tagProperties);
Then When I have to create a Tag (booelan in this case I do :
tagProvider.configureTag(tagPath, com.inductiveautomation.ignition.common.sqltags.model.types.DataType.Boolean, tagType);
and to set a value I do :
tagProvider.updateValue(tagPath, value, DataQuality.GOOD_DATA);
As I have set the TagProp.HistoryEnabled I suppose the History should have been activated, but it is not the case.
Some of the properties in TagProp should a value set, How do I set the properties values ?
