For wide project or OEM project with ignition a added value feature will be the possibility to create or modify via import/export a windows and these components thru an xml format.
Windows can already be exported and imported, which uses an XML format. Is this not what you’re talking about? ![]()
yes,
but with the functionexport, all the data in the .proj file are binary (<![CDATA … ]]>)
not possible to edit.
When we do a ctrl-C with all component selected, an the past it in a notepad,
the xml provided seem to be manually editable !
But when we try to import the saved file witha .proj extension,
the message is :
org.xml.sax.SAXParseException: Content is not allowed in prolog.
