I am attempting to work on an ignition project that utilizes Ubuntu 22.04.04 server. I continually get a Jar signature error when trying to launch the designer and none of the workarounds I have seen have worked.
As it seems like I will not be able to launch the designer directly on the ignition server, I am thinking of restoring a backup of the gateway on a Windows machine, making the edits to the project and tags there, and then putting that gateway back on the ignition server.
Will I run into any issues with the configuration of the gateway if I am going from one platform to another and then back again (Windows - Linux - Windows)?
You should never be doing this anyways. It can push a marginally-powered gateway over the cliff, and it hides any network configuration problems that would show up for external clients.
File paths and similar customizations in ignition.conf may prevent the gateway from starting after your restore. Be prepared to edit on the spot and restart.
