I am creating a cross-tab report that will be emailed as .csv file (+1 for .xlsx format
The rows will show plant and material data and total product quality. The columns show date. The report will be month-to-date so each day will have 1 more column added - then back to 1 column on first day of the month.
The problem I have is the .csv file has duplicate rows that I can’t figure out where they are coming from. As I was trying to simplify the report to find the smallest case that shows the issue I found it is related to the “reprint header rows” checkbox. When the option is true, the date headings repeat every 46 rows (46, 91, 136 etc.) When the option is false (un-checked) the data that is in row 46 gets repeated at rows 91, 136 etc.
Any ideas on what may be causing this.
Thanks,
-David
Ignition: 7.8.2 Data for report coming from MySql 5.2
