Cross Table Doesn't shows all the data
Hi everyone,
I'm having a problem with cross tables in the reporting module. I'm doing the example of the videos
But it is just showing this
I don't know what is happening because I did all of the video but is not working. Do you know what is missing?
Thank you!
The problem doesn't seem to be with the report. It's with the data. Property Inspector is showing you that you've only one row. See what's generating the data.
Thank you for your answer.
I'm doing the example in
https://docs.inductiveautomation.com/display/DOC79/CrossTab+and+Simple+Tables
And I have this in data but is not working
Thank you
Well I don't know what happened but I did the Simple table example and it worked and then I did again the Cross Table and It worked, maybe there was a problem with the data as you said :smiley:
Thank you!!
