Good day,
I am working on a project where one of the reports generated needs to make use of a crosstab element. Everything works fine until pagination onto the next page should occur, where it just cuts off.
What I am doing:
- Created a main table and then created a table group for this table.
- Set the data key for this main table as the main query. (This is to query for the multiple companies on their ID’s)
- Created a child table and set the data key for this child table to the sub query. (To query for the multiple details per company)
When I am querying one company ID at a time, the crosstab pagination works perfectly, as in the records gets printed over multiple pages according to the amount of records present for that ID.
But when I query multiple companies at a time, the crosstab cuts off at the end of every page as it generates the records, even cutting off at only 2 records for most companies; this is where no pagination occurs.
Btw, my queries generate the correct data, I’ve tested it - it just doesn’t get displayed correctly
I have tried the following:
- Using different types of tables (including the fact that a crosstab is needed)
- Moved the crosstab into different parts of tables
- Updated main and sub queries
- Made use of a single query and nested queries
I’m not sure if this is something I can fix on my side, or if this is a bug.
Any help regarding this issue would be appreciated.
Thanks, Laura
