Relatively new to CSS. Trying to create a style that applies the same effect as the buttons when the cursor is over the button (hand and boxShadow).
I located the button.css file in the install directory and tried to create a style following the layout of what I thought the relevant properties are for creating the hover effect, but I can't get it to work.
This is the button.css file:
.ia_button--primary,
.ia_button--secondary {
font-size: 0.875rem;
font-weight: 700;
border-radius: var(--borderRadius);
-webkit-border-radius: var(--borderRadius);
cursor: pointer;
-webkit-transition-duration: 0.1s;
transition-property: box-shadow, background-color;
.ia_button--primary:enabled:hover,
.ia_button--secondary:enabled:hover {
box-shadow: var(--boxShadow2);
/* Primary button */
.ia_button--primary {
background-color: var(--callToAction);
border: var(--containerBorder);
color: var(--neutral-10);
.ia_button--primary svg,
.ia_button--secondary svg {
fill: currentColor;
.ia_button--primary:enabled:active {
box-shadow: var(--boxShadow--inset);
border: none;
.ia_button--primary--disabled {
background-color: var(--callToAction--disabled);
border: var(--border--disabled);
color: var(--neutral-30);
cursor: not-allowed;
/* Secondary button */
background-color: var(--neutral-10);
color: var(--neutral-90);
.ia_button--secondary:enabled:active {
.ia_button--secondary--disabled {
background-color: var(--border--disabled);
border: 1px solid var(--border--disabled);
And the style I want to create:
.psc-Invisible_Button{
cursor: pointer;
box-shadow: var(--boxShadow);
.psc-Invisibe_Button:enabled:active{
border: none;
Applying the style to say, an SVG, doesn't change anything.
Will I be able to get this to work how I expect it to? Basically, I want to be able to apply this style to any object on the screen to make it more obvious to the user that they can click there.
