Hello again,
I have been trying to create a scrolling table for my module (so that the table does not expand to infinity). I have seen mixed methods of adding CSS to wicket projects, however, I have not been able to get it to work within ignition. Is there a certain way of adding custom CSS files to apply to specific panels that I have created? I am not very well-versed in web-development so I may be missing something, but from what I can tell, any CSS I’m adding is being overwritten by ignition’s defaults.
My code so far:
ActivityPanel.html
[code]<?xml version="1.0" encoding="ISO-8859-1" ?>
| message |
ActivityPanel.java
[code]public class ActivityPanel extends Panel {
public ActivityPanel(String id, int antennaID) {
super(id);
this.initComponents(antennaID);
private void initComponents(int id) {
IModel activityList = new LoadableDetachableModel()
protected Object load() {
return LRSManager.getLogsFor(LRSManager.getByID(id));
WebMarkupContainer listContainer = new WebMarkupContainer("activity-log-container");
ListView activityLog = new ListView("activity-log", activityList){
@Override
protected void populateItem(ListItem item) {
item.add(new Label("activity-message", item.getDefaultModelObjectAsString()));
listContainer.add(activityLog);
add(listContainer);
}[/code]
ActivityPanel.css
table {
width: 100%;
border-collapse: collapse;
td {
border: 1px solid black;
.scrollingTable {
width: 30em;
overflow-y: auto;
The ActivityPanel (whose CSS I’m trying to alter) is contained within a TabbedPanel which I have updating itself (every 30 seconds a heartbeat, or every time a message is sent)
LRSPage.html
Antenna ID:
[tabbed panel will be here] </wicket:extend>
[/code]
LRSPage.java
[code]public class LRSPage extends ConfigPanel{
public LRSPage() {
super("LRS.nav.LRSPageTitle");
this.initComponents();
private void initComponents() {
final Logger logger = LoggerFactory.getLogger(getClass());
//components for sending messages to antenna
Form form = new Form("form");
TextField<String> MESSAGE = new TextField<String>("message", new Model("message"));
NumberTextField<Integer> ANTENNA_ID = new NumberTextField<Integer>("antenna-name", new Model<Integer>(), Integer.class);
Button myButton = new Button("submit-button"){
public void onSubmit(){
try {
LRSManager.sendPage(Integer.parseInt(ANTENNA_ID.getValue()), MESSAGE.getValue(), 911);
} catch (Exception e) {
logger.error("On submit error: " + e.toString());
//finally, add them to the page
form.add(new Component[] { ANTENNA_ID });
form.add(new Component[] { MESSAGE });
form.add(new Component[] { myButton });
this.add(new Component[] { form });
//displaying each antenna activity logs
List<ITab> tabsList = new ArrayList<ITab>();
for(Integer id: LRSManager.getAllConnectionNames()){
AbstractTab tab = new AbstractTab(Model.of("Antenna " + id)){
public WebMarkupContainer getPanel(String panelId) {
return new ActivityPanel(panelId, id);
tabsList.add(tab);
TabbedPanel activityPanel = new TabbedPanel("tabs", tabsList);
activityPanel.setOutputMarkupId(true);
activityPanel.add(new AjaxSelfUpdatingTimerBehavior(Duration.seconds(1)));
add(activityPanel);
}[/code]
