Hi Gents,
I am trying to read in a CSV File with the following data.
Date First Weight Weight1 DateSecondWeight Weight2
20/05/2009 08:09 16240 20/05/2009 08:38 10940 5300 106012 9896 PEAT SCREEN DEB
20/05/2009 08:21 44400 20/05/2009 08:40 16980 27420 106014 9861 INCOMMING PEAT
20/05/2009 09:50 42520 20/05/2009 10:06 18240 24280 106015 9863 INCOMMING PEAT
20/05/2009 10:16 44740 20/05/2009 10:42 17060 27680 106016 9889 INCOMMING PEAT
The problem is that the date/time format is dd/mm/yyyy hh:MM, what i need to log into database is
yyyy-mm-dd hh:MM:ss
What i have so far tried is this:
import system
path = fpmi.file.openFile("csv")
if path != None:
text = system.file.readFileAsString(path)
line = text.split("\n")
for i in range(len(line)-1):
#This will get the words as a list of strings
Column = line[i].split(",")
#Date format we have 20/05/2009 08:09
#We Need 2009-05-20 08:09:00
result = system.db.runQuery("SELECT STR_TO_DATE('"+ Column[0]+"','%d/%m/%Y %h:%i')")
print "Before :\t\t / After: "
print [str(Column[0])+ ", " + str(row[0]) for row in result]
The Idea here is that the converted date then gets inserted into the Database TABLE CSV_IMPORT
with all the other data.
However the printed output is this:
Before : / After:
['20/05/2009 08:09, Wed May 20 08:09:00 BST 2009']
Before : / After:
['20/05/2009 08:21, Wed May 20 08:21:00 BST 2009']
Before : / After:
['20/05/2009 09:50, Wed May 20 09:50:00 BST 2009']
Before : / After:
['20/05/2009 10:16, Wed May 20 10:16:00 BST 2009']
Any Help would be great, thanks
