Hi -
I am having issues importing a data from a CSV to a database. I have had the below code work in other projects without issues, but for some reason not all CSV rows are being found when the script is ran. The CSV is updated daily and the goal is to run the delete/import daily as well. The only way I have found to solve the issue is to open the CSV(excel), save it(w/o any modification), and then it imports without issue. I believe it has something to do with the CSV file or how it is created, but am unable to find any differences when comparing it other CSV files we use. Has anyone seen an issue like this before?
ERROR:
File “event:actionPerformed”, line 11, in reupload
IOError: CSV invalid: rows missing. Found 1722, expected 3333.
Ignition v8.0.2 (b2019060511)
Java: Azul Systems, Inc. 11.0.3
if system.gui.confirm("Update NCCA Data?", "Update", 0):
window = system.nav.openWindow('Popups/NCCA/Loading')
system.nav.centerWindow(window)
#Delete NCCA data
system.db.runUpdateQuery("DELETE FROM B40_NCCA", "NX_Ignition")
def reupload():
#import .csv data
file_path = 'N:\ALLSHARE\Ignition\NCCA\ALL CAR REPORT - IGNITION.csv'
data_string = system.file.readFileAsString(file_path)
data = system.dataset.fromCSV(data_string)
data2 = system.dataset.toPyDataSet(data)
for index in range(len(data2)):
rowData = list(data2[index])
system.db.runPrepUpdate("INSERT INTO B40_NCCA (CarNumber, CarTitle, CarInvestigator, CarRespBusinessModule, CarPartNumber, CarIssueInd, CarCreateDate, CarDaysOpen, CarState, CarSevRating, CarDaysSinceUpdate, D3TargetDate, D4TargetDate, D5TargetDate, D6ImplementationTargetDate, D2Date, D3Date, D4Date, D5Date, D6Date, D7Date, CarLastUpdateDate, CarDataSource, CarSupplierNumber, CarSupplierName, CarOriginator, CarVerifier, CarChampion, CarSecondInvestigator, CarType) VALUES (?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?)", rowData, "NX_Ignition")
#update time label
date = system.date.now()
system.tag.write('[default]NCCA/updateDateTime', date)
system.nav.closeWindow('Popups/NCCA/Loading')
system.gui.messageBox("CSV file successfully uploaded.")
table = event.source.parent.getComponent('NCCA Table')
system.db.refresh(table, "data")
system.util.invokeAsynchronous(reupload)
