I think your best solution will be to use a DB query to do your running totals.
Below are a couple of SQL queries that might work for you with simple alterations.
FYI, I’ve also included the code that I used to create my test table and data. I developed this on MS SQL Server 2005. The first query should work for both MS SQL Server and MySQL. The second uses a Common Table Expression (i.e., CTE) which works only in MS SQL Server.
Code to create test table:
USE [DatabaseName]
GO
/****** Object: Table [dbo].[Production] Script Date: 02/10/2010 20:35:48 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[Production](
[day] [datetime] NOT NULL,
[shift] [tinyint] NOT NULL,
[hour] [tinyint] NOT NULL,
[target] [int] NOT NULL,
[actual] [int] NOT NULL,
CONSTRAINT [PK_Production] PRIMARY KEY CLUSTERED
[day] ASC,
[shift] ASC,
[hour] ASC
)WITH (PAD_INDEX = OFF, IGNORE_DUP_KEY = OFF) ON [PRIMARY]
) ON [PRIMARY]
Code to populate table with test data:
[code]DECLARE @Date datetime
DECLARE @Shift tinyint
DECLARE @Hour tinyint
SET @Date = ‘20100201’
WHILE @Date < ‘20100210’ BEGIN
SET @Shift = 1
WHILE @Shift <= 3 BEGIN
SET @Hour = 0
WHILE @Hour <= 7 BEGIN
INSERT INTO Production
SELECT @Date, @Shift, @Hour, 525, 525 + rand() * 10 - 10
SET @Hour = @Hour + 1
END
SET @Shift = @Shift + 1
END
SET @Date = dateadd(day, 1, @Date)
END
SELECT *
FROM Production
[/code]
Code to query table for running totals:
[code]-- MS SQL Server & MySQL running total query
SELECT p.day,
p.shift,
p.hour,
(SELECT sum(t.target)
FROM Production t
WHERE t.day = p.day AND t.shift = p.shift AND t.hour <= p.hour
) AS target,
(SELECT sum(a.actual)
FROM Production a
WHERE a.day = p.day AND a.shift = p.shift AND a.hour <= p.hour
) AS actual
FROM Production p
– MS SQL Server running total query using CTE
; – Need semicolon before WITH statement
WITH ProductionCTE(day, shift, hour, target, actual)
AS
SELECT day,
shift,
hour,
target,
actual
FROM Production
SELECT day,
shift,
hour,
(SELECT SUM(target) FROM ProductionCTE cte1 WHERE cte1.hour <= cte3.hour AND cte1.day = cte3.day AND cte1.shift = cte3.shift) AS target,
(SELECT SUM(actual) FROM ProductionCTE cte2 WHERE cte2.hour <= cte3.hour AND cte2.day = cte3.day AND cte2.shift = cte3.shift) AS actual
FROM ProductionCTE cte3
[/code]
