Current date just once Popup Calendar Vision
Hello Everyone
I have a report that gets the input dates through 2 calendar popups.
Everything is working ok and I just want to start the dates by default with the actual date (The final date is NOW() and the initial date is dateArithmetic(now(),-15,'days') ) but when I try to put a different day the calendar is updated each second.
I just need that the date take just one time the current date and then the customer can modify the date as he wants but currently the customer select a date and a second later the date is updated to the current date.
I really appreciate your help with this that should be so easy but I'm a little bit lost.
now(0) if you want it to execute just once. Otherwise it's executed at the default scan rate.
https://docs.inductiveautomation.com/display/DOC81/now
Oh - you might want to fix your question title.
Thank you very much! I knew was easy but I was confused.
Thank you again!
