I have written a Value changed script for a memory tag in which i used below condition,
if ( previousValue.value != currentValue.value and currentValue.value == 1 ):
it worked for earlier days, now i found out that it is not working anymore. So i changed it as
vCheck =system.tag.readBlocking(“[.]DBDataStoreTriggerHr”)[0].value
if (vCheck== 1 ):
I would try making some memory tags and writing values to those as a test, try changing the value and check those memory tags. If nothing changes then your script isn’t compiling, probably because of an error
