I feel like I’m missing something, but I have two seemingly identical DateRange components, as far as property settings, in different windows, and the cursor will change from pointerto resize to hand based on window position relative to the selected range on one component and remain constant (as the pointer) on the other, with the former being the desired behavior. Both cursor selections are set to default. The only differences I can think of are the desired DateRange component is in a popup window and is significantly larger than the other. Any input is appreciated.
