Hi Guys,
Slightly new tweak to an older solved issue >> http://www.inductiveautomation.com/forum/viewtopic.php?f=70&t=10922
I have a Popup which contains multiple instances of the same template. The template has a button to call another popup at the cursors location.
Using the code below I can get it working for only 1 instance of the template.
mouseX = event.x
mouseY = event.y
compX = event.source.getX()
compY = event.source.getY()
parWindow = system.gui.getParentWindow(event)
windowX = parWindow.getX()
windowY = parWindow.getY()
window = system.nav.openWindow("Popups/Popup")
window.setLocation(mouseX+compX+windowX,mouseY+compY+windowY)
Is there a way to some how use the unique name of the template instance that the event is occurring in?
event.source.parent.name
gives me the template name but not the instance name…
Cheers for any pointers
Tim…
