Custom Fonts in Ignition 8.3
Hello,
I’m trying to add a custom font in Ignition 8.3 without success. I’ve created the custom font through API, resulting in the following resource.json and an empty “{}” config.json. Since that didn’t work, I’ve tried adding the font.css file to the theme and importing it in the index.css. That didn’t work either.
When I check through API, the theme is listed and the files are there (and not corrupted; I’ve checked). Does anybody have a suggestion on what to try next or has successfully added a custom theme in Ignition 8.3?
Thanks in advance.
The last post in that thread states this no longer works for 8.3 which is what the OP asked for.
Read this: Custom Fonts in 8.3 Beta - #8 by paul-griffith
hasty reading is my downfall once again, thanks for the correction.
