Custom Icon Library Not Loading in Ignition
Hi everyone,
I’ve created a custom icon library and placed it in the advised path according to the Ignition documentation. However, the icon library is not appearing, even after restarting both the gateway and the designer.
Am I missing a step in the setup? Any guidance would be greatly appreciated.
Thanks in advance!
https://docs.inductiveautomation.com/docs/8.1/ignition-modules/perspective/working-with-perspective-components/images-and-icons-in-perspective#use-a-custom-icon-repository
<?xml version="1.0" encoding="utf-8"?>
<svg xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink">
<!--misc-->
	<svg viewBox="0 0 16 16">
		<g class="icon" id="misc-placeholder">
			<path d="M8,14v-6l5,-3l-5,-3l-5,3v6l5,3Zm5.28,-10l7.01697e-08,4.23078e-08c0.460688,0.277765 0.735882,0.782288 0.72,1.32v5.53l4.04732e-08,-8.90645e-06c-0.00237284,0.522501 -0.274699,1.00664 -0.719992,1.28l-4.5,2.73l2.01724e-08,-1.2749e-08c-0.476415,0.301093 -1.08359,0.301093 -1.56,2.54979e-08l-4.5,-2.73l-1.15263e-07,-7.07569e-08c-0.445297,-0.273356 -0.717628,-0.757495 -0.720007,-1.28v-5.53l-5.96978e-08,-2.02118e-06c-0.0158816,-0.537712 0.259313,-1.04223 0.720002,-1.32l4.5,-2.7l2.81283e-08,-1.69691e-08c0.479732,-0.28941 1.08027,-0.28941 1.56,-1.50799e-08Z"></path>
			<path fill-opacity="0.36" fill-rule="evenodd" d="M3,5l5,3v6l-5,-3Z"></path>
		</g>
	</svg>
	 <!-- Red Tank1 -->
    <svg viewBox="0 0 24 24" id="Enlive-recipe">
		<path d="m22.09034,19.13472l-6.83001,-10.50792l0,-5.0231l1.58673,0l0,-2.7517l-9.68854,0l0,2.75449l1.59974,0l0,5.0231l-6.84302,10.50513c-0.26477,0.4004 -0.4227,0.89184 -0.4227,1.41951c0,1.43252 1.16125,2.59377 2.59377,2.59377l0.00279,0l15.8218,0c1.43438,-0.00279 2.59656,-1.1659 2.59656,-2.6012c0,-0.52489 -0.15514,-1.01354 -0.4227,-1.4223l0.0065,0.01022l-0.00093,0zm-0.84075,2.13856c-0.26198,0.47658 -0.75992,0.79337 -1.33219,0.79337c-0.00186,0 -0.00372,0 -0.00557,0l-15.82273,0c-0.00093,0 -0.00186,0 -0.00279,0c-0.83982,0 -1.51984,-0.68003 -1.51984,-1.51984c0,-0.30657 0.09104,-0.5927 0.24711,-0.83146l-0.00372,0.00557l7.01302,-10.7764l0,-5.34268l4.35329,0l0,5.34547l7.00559,10.7764c0.15793,0.23318 0.25269,0.52117 0.25269,0.83146c0,0.26477 -0.06875,0.51374 -0.18952,0.72927l0.00372,-0.00743l0.00093,-0.00372z" />
		<path d="m15.0945,11.8246l-6.191,0l-5.655,8.698c-0.03,0.045 -0.048,0.1 -0.048,0.159c0,0.051 0.013,0.098 0.036,0.14l-0.001,-0.001c0.05,0.087 0.142,0.145 0.248,0.146l17.031,0l0.001,0c0.106,0 0.198,-0.058 0.247,-0.145l0.001,-0.001c0.022,-0.04 0.036,-0.088 0.036,-0.138c0,-0.059 -0.018,-0.115 -0.049,-0.16l0.001,0.001l-5.657,-8.699z" />
    </svg>
    <!-- EMG Reset -->
    <svg viewBox="0 0 24 24" id="Enlive-emgreset">
		<path d="m12.00002,1.17017l0,2.40663c4.91057,0 8.90749,3.77842 8.90749,8.4232s-3.99692,8.4232 -8.90749,8.4232s-8.90749,-3.77842 -8.90749,-8.4232c0,-2.22252 0.93528,-4.31509 2.545,-5.87458l0,2.8663l2.54498,0l0,-6.61821l-6.99874,0l0,2.40663l2.27904,0c-1.85784,1.9638 -2.91529,4.52326 -2.91529,7.21987c0,5.97084 5.13707,10.82982 11.45247,10.82982s11.45247,-4.85898 11.45247,-10.82982s-5.13707,-10.82982 -11.45247,-10.82982" transform="rotate(-180 12 12)"/>
		<path d="m8.29605,16.77294l0,-1.05827l0.84662,0l1.26992,-4.23307l3.1748,0l1.26992,4.23307l0.84662,0l0,1.05827l-7.40788,0zm3.1748,-6.34961l0,-2.64568l1.05827,0l0,2.64568l-1.05827,0zm3.14835,1.3096l-0.75402,-0.75402l1.87844,-1.8652l0.74079,0.74079l-1.8652,1.87844l-0.00001,-0.00001zm0.5556,2.39433l0,-1.05827l2.64568,0l0,1.05827l-2.64568,0zm-5.79403,-2.39433l-1.8652,-1.87844l0.74079,-0.74079l1.87844,1.8652l-0.75402,0.75402l-0.00001,0.00001zm-3.20126,2.39433l0,-1.05827l2.64568,0l0,1.05827l-2.64568,0z"/>
	</svg>
    <!-- Simple Gauge -->
    <svg viewBox="0 0 24 24" id="enlive-gauge">
		<path d="m9.84428,15.97488c-0.793,1.37768 -0.25896,2.50906 0.84249,3.14438c1.1003,0.63647 2.34908,0.53519 3.14438,-0.84249c0.793,-1.37538 5.80881,-13.65594 5.3726,-13.908c-0.43621,-0.25206 -8.56532,10.22958 -9.35947,11.60611zm2.15572,-8.74717c0.50411,0 0.99442,0.04258 1.47436,0.12545c0.50411,-0.63187 1.06808,-1.32819 1.61708,-1.98883a11.12272,11.12272 0 0 0 -3.09143,-0.43851c-6.45334,0 -11.50943,5.44281 -11.50943,12.39106c0,0.427 0.01842,0.854 0.0564,1.26949c0.0564,0.63417 0.62151,1.09915 1.24762,1.04506c0.63417,-0.0587 1.10145,-0.61575 1.04506,-1.24992a12.04117,12.04117 0 0 1 -0.04719,-1.06462c0,-5.65804 4.04442,-10.08917 9.20755,-10.08917zm8.30866,1.43868c-0.32111,0.86321 -0.66064,1.74253 -0.95989,2.50215c1.16821,1.69189 1.85877,3.81423 1.85877,6.14834c0,0.3637 -0.01726,0.73085 -0.04949,1.08534a1.15209,1.15209 0 0 0 2.29268,0.20947c0.03798,-0.42585 0.0587,-0.86091 0.0587,-1.29481c0,-3.39989 -1.21194,-6.43377 -3.20077,-8.65049z" />
	</svg>
    <!-- Thermometer -->
    <svg viewBox="0 0 24 24" id="enlive-thermometer">
		<path d="m15.47073,6.766l5.70737,0l0,1.63067l-5.70737,0l0,-1.63067zm0,4.89204l8.15339,0l0,1.63067l-8.15339,0l0,-1.63067zm0,4.89204l5.70737,0l0,1.63067l-5.70737,0l0,-1.63067zm-8.15339,-1.48066l0,-10.74943l-1.63067,0l0,10.74943a2.44602,2.44602 0 1 0 1.63067,0z" />
		<path d="m22.76145,2.7722l-13.08748,0a3.83031,3.83031 0 0 0 -6.8981,2.30603l0,8.53999a5.38073,5.38073 0 1 0 7.68677,0l0,-8.53999a3.84492,3.84492 0 0 0 -0.07763,-0.76868l12.37646,0l0,-1.53736l-0.00002,0zm-16.1422,18.44822a3.83799,3.83799 0 0 1 -2.56122,-6.70133l0.2552,-0.22983l0,-9.21104a2.30603,2.30603 0 0 1 4.61205,0l0,9.21104l0.2552,0.22983a3.83799,3.83799 0 0 1 -2.56122,6.70133l-0.00002,0z" transform="matrix(1 0 0 1 0 0)" />
	</svg>
    <!-- Flow -->
    <svg viewBox="0 0 24 24" id="enlive-flow">
		<path d="m23.27168,11.69942l-8.80154,-4.61272l2.69749,4.9133l-2.79383,4.91329" />
		<path d="m10.96277,11.5345l2.43576,0l0,7.97995l-2.43576,0l0,-7.97995zm0.28417,-7.04895l0,6.11796l1.86742,0l0,-6.11796l-1.86742,0z"transform="rotate(-90 12.1807 12)" />
		<rect width="3.27553" x="0.72832" y="11.13295" />
	</svg>
	<!-- Panel -->
    <svg viewBox="0 0 24 24" id="enlive-panel">
	  <rect fill="black" height="1.25786" width="23.34906" x="0.28616" y="5.1195" />
	  <rect fill="black" height="1.25786" width="23.34906" x="0.32547" y="17.54088" />
	  <rect fill="black" height="9.04088" transform="matrix(1 0 0 1 0 0)" width="22.32704" x="0.83648" y="7.47956" />
	</svg>
</svg>
Don't you already have a topic for this? Paul told you to look for errors loading your library in the gw wrapper
There you were making joke.
I've found circling your mouse three times clockwise, then moving it to the right and holding it for 5s, jumping up and down 6 times, and saying "alakazam" has little to no effect. But it's certainly worth a shot!
Exactly, but there were other replies in there offering other useful suggestions. Don't create multiple topics for a single topic. I'm going to merge them
