Custom Icon Library
I have created a custom subset library for material icons to reduce loading times on a flex repeater, but wondering if this custom library would be included in a gateway backup.
Also, is there a way to include this custom library in the dropdown for the explorer? For now, I've just had to manually type paths.
Maybe go through this thread first.
Custom Icons in Perspective - Ignition - Inductive Automation Forum
I've done that. The icons display if I enter the path manually, but my new library file doesn't show up in the "icon picker" dropdown menu.
I haven't tried this myself. I was hoping the other thread's troubleshooting might help you out.
Have you restarted the designer since adding your custom library? It looks like the choices in the list are lazy-loaded and cached once, on designer initialization.
Yep, that'll do it.
I had actually just restarted after my last response and got busy so I hadn't checked yet.
As for your other question,
My understanding is that yes, they will be, but you can always try on a test system to confirm.
@paul-griffith, @amarks
I can confirm that the custom library are inside a gateway backup
