Custom Perspective Symbol States Not Working
I am trying to use perspective symbol states specifically for the motor component. I need to create custom symbol states for Manual On/Off which have a designated color scheme.
The issue I am running into is that any custom style that I create seems to default to a gray color no matter what colors I edit within the state style.
For example, the state you see below is a copy of the "running" style that I renamed "manualOn", everything else is the same.
Recording 2026-06-03 123613
When I attempt to test the new state, the motor turns Gray and has no animation. I have tried to restart the designer and restart the gateway but with no luck. I have tried to create states from scratch and copy as the example shows above. I am on Ignition Platform 8.3.2 and using perspective module 3.3.2.
Recording 2026-06-03 123330
Does anyone know what is causing this issue?
Appreciate any help!
This might be an un-intended bug on the newer version(s)? I tried in on a project I had at gateway version 8.3.3 with perspective module version 3.3.3 and it also did not work for me.
I then tried it on a different project I have that is gateway version 8.1.53 and perspective module 2.1.53 and it worked fine.
