Is it possible to add "Perspective Symbols" (like the motors, pumps, sensor, valve, vessel) by adding svg/css files to perspective file structure?
You can upload svg files into the Image Management tool Images, SVGs, and Icons in Perspective - Ignition User Manual 8.0 - Ignition Documentation
You can also just drag svg files directly into your designer and have them populate that way if you don't want them uploaded into the Image Management tool.
