When we set up custom properties, we are able to set three characteristics (properties) for each property:
Name
Type
Description
So if I create a custom property with these characteristics:
Type: Integer
Description: Valve position
Can I reference the description indirectly? If so, what is its property name? I’ve tried “Description” and that doesn’t work.
nmudge
2
The custom property data can be accessed through scripting.
Here is an example. event.source could be any component. The example prints information about each custom property that exists on the component.
for property in event.source.getDynamicProps().values():
print "Name:",property.getName()
print "Description:",property.getShortDescription()
print "Type:",property.getPropertyType()
print "Value:",property.getValue()
print
Thank you, that works great.
