I have a custom property named daywork that is a dataset. In the property change event I narrow down the event based on the property name, but it doesn’t fire. Any ideas?
if event.propertyName == 'daywork':
do something
EDIT: Removing the property name if statement causes the script to fire twice. I then tried using print event.propertyName to see what properties were changing, and it shows visible and text. (Visible property change is from my script)
