Custom Session Properties Gone
This is the second time this has happened to me where my custom session properties are gone. I had approx. 20 of them and at some point they just disappeared.
I see a lot of other posts about people losing bindings to them among other things but I don't believe I saw one where the session properties were essentially deleted.
Does anyone else ever experienced this problem?
The Ignition Edge version is 8.1.23
Did you export / import from another project, by any chance?
Ignition export
I think I experienced session props loss when I exported them from one project into another. I expected them to be merged but it seemed to replace them in the destination project. You could test it out quite quickly.
Nope. Nothing was working on the project yesterday and now today once I opened it up and looked at a screen and bindings were failing. They were bounded to custom session properties and I looked and they were just gone.
did you session properties have bindings on them? I have seen sometimes where the properties would disappear but if i added a prop with the same name it would show back up.
I think the reason they were gone is the binding associated with the property was failing.
Same here, I had experience this, when hibernating my machine with designer opened, and the next day star working something happened that the session custom props disappeared... More than ones, and a work mate suffers the same many times..
We opened a ticket but we were never able to recreated it, it happens to me working with 8.1.20
Some had bindings, approx 5. And the others did not.
Did you upgrade to 8.1.26 recently by chance?
Hi, this has happened to me a few times. Most recently today. I'm running Version 8.1.27 on a MacBook Pro. Discouraging to see that this hasn't been solved despite years of bug reports.
It's to the point where I can't confidently use any Custom Session Properties which is a shame because they're very useful when they stick around. If I'm missing anything or there's a fix, please let me know. Thanks.
Making them persistent should fix the issue.
Thank you, Pascal. I have made that change. I'll reply back to this thread if they disappear again.
Is this still an issue? All my custom session props, including bindings, disappeared. Theme selection disappeared as well.
I can't pinpoint a change to the environment that triggered this. I'm running 8.1.28 on this gateway.
Perhaps peek at the \com.inductiveautomation.perspective\session-props\props.json file to see if the props are in the file? Maybe they were somehow marked persistent = false?
Hey @jlandwerlen thanks for the reply. I don't have a session-props folder inside data\modules\com.inductiveautomation.perspective nor can I find anything about that folder or props.json in the Ignition docs. Have any more info on where I could find more on this?
You're not looking in the right place.
Try .../ignition/data/projects/{project_name}/com.inductiveautomation.perspective/session-props
Sorry if I gave the incorrect path.
As jland said, the persistent property on them was likely equal to false which means they are lost during an upgrade. I learned this the hard way as well
I had this issue happen to me again (probably the 4th or 5th time). All of my custom session properties are set to persistent and they all just disappeared by themselves. Luckily I've gotten good at manually reimporting a saved export of just the session properties so I only had about 10 minutes of downtime. Curious if I can set up some external logging that tries to dig into this issue for when it happens the next time, which it has proven it will continue to do.
Still having the same issue in 8.1.44. It seems to me like it's related to bad connectivity to the gateway while using the designer, but I don't have a way to confirm this.
I’ve been working on a project for about 6 months, and I have custom session properties with several bindings. I’ve been the only one working on this project in the designer so far.
In the last two days, a colleague has started helping me. The strange thing is that in the past two days, I’ve noticed a couple of times that some custom session properties disappear for no apparent reason.
I imported a backup into another empty project, copied the custom session properties, and simply pasted them into the project I’m working on. The strange part is that as soon as I paste them, the tags reappear, but they already have their bindings. Usually, when you just copy and paste (not copy binding), the bindings are not imported.
This behavior suggests that the session custom tags might have been invisible.
It happened again for no apparent reason.
I just saved the project, closed it, and checked it in the browser, but everything was in error.
When I reopened the project, all the session custom had disappeared. I had to import them from a backup, and they magically reappeared with all bindings, script changes, and everything else.
This is strange, but most of all, worrying.
