I’m looking to create a UDT where nested memory tag names can be customized per instance. For the instance, the name property appears to be greyed out and doesn’t have an option for attaching a parameter. Is there a way to do this? Would nesting UDT’s be helpful here?
Nope, sorry. For some things, UDTs are not the answer.
However you could use a custom field instead to store the name of the tag, or a dataset tag with a lookup
